Hello all,
I need to clarify some things about power supply for CubeCell devices…
I would like to use AB-01 (ver 1.2 and ver 2 in the near future) for my outdoor device project.
Also I would need to check the battery status time to time - there is example code for this…
As far I know I can connect to AB-01 solar panel and LiPo battery in the same time.
For solar panel we have VS pin and for Lipo we have dedicated plug JST 1.25.
So here I have some questions:
- if we have these two things - VS pin and JST 1.25 - is it means that battery would charge from sun?
 so AB-01 can charge batteries like usual charge module?
- also we have Vin pin for external power supply which can be 5V and VDD pin which can be used only with 3.3V power source.
 But if I want to use battery as power source - I can ONLY use JST 1.25 connector and NOT VDD or Vin?
- also - measuring of battery status (voltage) possible only with battery connected to JST?
So finally - I can use only JST and VS for power supply for my device? There no any other variants? This is the only correct way to have LiPo solar charger and battery measuring?
